Hey all,
Motherboard Model is: Intel Z490 Ace
The issue is the following:
There is a strange electric noise(not coil whine) coming close to the cpu/back io shield/vrm area.
Links with the sound in videos below:
1.Under Load:
View: https://www.youtube.com/watch?v=G-6UkHHltqg&ab
2. No load (constant sound):
View: https://www.youtube.com/watch?v=eCUF-CJoG20&ab
Specs of the system are:
CPU: i9-10900k which I am not overclocking but let it boost by itself. I am only using MSI's default settings and did not change anything in the BIOS.
GPU: MSI RTX 2070 Ventus (not overclocked)
PSU: Corsair RM750x (750watt)
RAM: Corsair Vengeance 16gb 3200mhz (I have checked and it is compatible with the MOBO)
Cooling System: It is a 360 liquid cooler so the temperatures are max 30 on iddle and max 65 on load
I would like to comment here that the only change in my system was the MOBO and CPU. My previous MOBO was an MSI z390 carbon and I had zero issues with it. I made sure that this noise is not coming from the GPU or PSU, fans or any other part.
What I have tried already:
1. Cleared CMOS and reset to optimal settings: Did not fix the issue
2. Disabled Intel EIST, C State and C1E: Did not fix the issue
3. The third action I was asked to perform is set a specific CPU ratio which I did and not fixed the issue.
Could you please assist me with this issue as I would like to be able to use my PC without being afraid that I will destroy my CPU?
Thank you very much in advance and sorry for the long post.
1.Under Load:
