Alright, so recently my PC has been acting up. For example, sometimes I'd log into my USER and there would be no wallpaper, icons, cursor, nothing. Nothing except for my auto-run programs booting up. I'd restart and the problem would be fixed.
A few days ago this happened, naturally I restarted but only to find that this time I'd get no display. I tried several things so far. I've tried:
- Reseating everything
- Resetting CMOS
- Tested PSU
- Tested GPU
- Tested RAM
- Made sure cables are connected properly
- Powering on with nothing but CPU and one RAM stick
- Unplugging and holding power button for a minute
- Putting new thermal paste
- Dusting out PC
I took it to a repair shop and they told me they thought it was the CPU, but couldn't say for certain because they didn't have a CPU of the same socket to test it out. I'm looking into buying a CPU right now but I get an odd feeling there's a strong chance it could be the motherboard as well. Everything powers on fine in the PC, the only issue is the no display. When I was reapplying thermal paste earlier I looked at the motherboard pins and I felt as though there was a pin or two that was slightly bent but it was extremely difficult to tell because of how small it is and the fact that the rest of the pins all have a slight curve facing towards the middle of the socket (at least that's what it looked like). I tried bending the pins I thought at fault ever so slightly to see if that could be it, but still no display signal. Just a few minutes ago I tried powering it on and it turned on for half a second then restarted. Only time that's happened during this entire issue, figured it's still worth mentioning. Hope I can get some help.
Specs:
Intel i7-5820k
MSI x99A Gaming 7
Gigabyte GeForce GTX 970 G1 Gaming
48GB DDR4 2800MHz (used to be 64gb but one stick went bad)
256GB SSD
x2 1TB WD HDD
Corsair H100i Water Cooling
- Resetting CMOS
- Tested PSU
- Tested GPU
- Tested RAM
- Dusting out PC
Specs:
Intel i7-5820k
MSI x99A Gaming 7
256GB SSD
x2 1TB WD HDD
