Question Motherboard overheating? GPU or SSD issue?
Feb 9, 2020
In recent weeks/months my desktop PC has seemed to slow down a bit and be laggy at times - I ignored and figured its just getting old. I built it in 2014, only upgrading the GPU a couple times since then. Two days ago though I moved it to another room in the house and now my games are playing at 20-30 fps.
I did a dust cleaning and inspected the hardware, fans, cables, etc. (albeit I'm a noob) and didn't see anything, it's all snug and tight. But I downloaded HW Monitor and noticed two of the motherboard temp gauges: TMPIN5 is at 127C and TMPIN8 is at 0C. I don't know what it means though. Anyone know if this is bad? Pasting entire output of monitor here in case you see anything else out of whack that could be slowing down the comp.
Appreciate any help - thanks fam.
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.1.0
Monitoring
Mainboard Model Z97 U3 PLUS (MS-7922) (0x000004E8 - 0xEA942CC4)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6792
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC9
LPCIO Revision ID 0x11
Config Mode I/O address 0x4E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 38 20 08 00 FF FF
20 C9 11 FF 00 04 00 40 11 00 FF 40 00 00 04 00 09
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 20 0A 30 00 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A20
Hardware Monitors
Hardware monitor Nuvoton NCT6792
Voltage 0 0.88 Volts [0x6E] (CPU VCORE)
Voltage 1 1.01 Volts [0x7E] (VIN1)
Voltage 2 3.39 Volts [0xD4] (AVCC)
Voltage 3 3.38 Volts [0xD3] (3VCC)
Voltage 4 1.02 Volts [0x80] (VIN4)
Voltage 5 0.90 Volts [0x70] (VIN5)
Voltage 6 0.74 Volts [0x5C] (VIN6)
Voltage 7 0.73 Volts [0x5B] (VIN7)
Voltage 8 0.88 Volts [0x6E] (VIN8)
Voltage 9 0.74 Volts [0x5D] (VIN9)
Voltage 10 1.02 Volts [0x80] (VIN10)
Voltage 11 1.01 Volts [0x7E] (VIN11)
Voltage 12 0.74 Volts [0x5C] (VIN12)
Voltage 13 1.02 Volts [0x7F] (VIN13)
Voltage 14 0.00 Volts [0x0] (VIN14)
Voltage 15 1.69 Volts [0xD3] (VIN15)
Temperature 0 29 degC (84 degF) [0x1D] (SYSTIN)
Temperature 3 28 degC (82 degF) [0x1C] (TMPIN3)
Temperature 5 127 degC (260 degF) [0x7F] (TMPIN5)
Temperature 6 29 degC (84 degF) [0x1D] (TMPIN6)
Temperature 8 0 degC (32 degF) [0x80] (TMPIN8)
Fan 0 1150 RPM [0x47E] (SYSFANIN)
Fan 1 590 RPM [0x24E] (CPUFANIN)
Fan 2 1448 RPM [0x5A8] (AUXFANIN0)
Fan 3 1025 RPM [0x401] (AUXFANIN1)
Fan 4 1436 RPM [0x59C] (AUXFANIN2)
Hardware registers
bank 0
00 04 1F 04 1F 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 99 04 99 04 99 03 7F 40 7F 5B 00 7F 5D EC 00
20 6E 7E D3 D3 80 70 5C 1D FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 00 40 FF DF 00 3F FF 2D FF FF 10 00 55 00 A3
50 05 FF FF FF FF FF FF FF C1 FF FF FF FF 47 06 FF
60 28 F0 FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 1C 80 1C 80 1C 80 1C 80 1C 80 28 80 FF
80 FF 7F 3F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 03 00
B0 00 00 00 00 00 00 27 00 04 00 00 01 40 C0 04 00
C0 FF FF FF FF FF FF FF FF FF 08 04 02 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 C0 1F 88 FF FF FF
bank 1
50 7F 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
50 00 F3 FF FF 00 00 00 FF FF 3E 13 33 09 00 FF FF
80 6E 7E D3 D3 80 70 5C D9 D1 7F 53 00 7F 5D EC 00
90 1D 7F 28 29 80 C4 00 27 C0 1D 1D 1D 1D 1D 00 28
A0 FF 1D FF FF FF FF 1F 1F 99 99 99 00 00 00 00 00
B0 24 16 47 10 1D 02 29 05 1D 0C FF 1F 00 00 FF FF
C0 04 7D 02 4E 05 AB 04 01 05 9C 00 00 FF FF FF FF
D0 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
F0 1D 00 00 00 1D 00 00 00 00 00 00 00 00 00 00 FF
bank 5
50 D9 D1 C0 FF 00 00 00 00 00 00 00 00 00 00 00 00
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 0.63 Volts [0x271] (GPU)
Power 0 7.20 pc (GPU)
Temperature 0 37 degC (98 degF) [0x25] (GPU)
Fan 0 0 RPM [0x0] (GPU #0)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 607.50 MHz [0x25F] (Graphics)
Clock Speed 1 405.00 MHz [0x195] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
Number of sockets 1
Number of threads 8
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Manufacturer GenuineIntel
Name Intel Core i7 4770K
Codename Haswell
Specification Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84.0 Watts
Tjmax 100.0 °C
Core Speed 800.1 MHz
Multiplier x Bus Speed 8.0 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 100.0 MHz
Stock frequency 3500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
Microcode Revision 0x25
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 35x
Max turbo ratio 39x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 39x
Ratio 2 cores 39x
Ratio 3 cores 38x
Ratio 4 cores 37x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 84.0 W @ 35x
Temperature 0 28 degC (82 degF) (Package)
Temperature 1 27 degC (80 degF) (Core #0)
Temperature 2 26 degC (78 degF) (Core #1)
Temperature 3 28 degC (82 degF) (Core #2)
Temperature 4 26 degC (78 degF) (Core #3)
Voltage 0 +0.00 Volts (IA Offset)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.00 Volts (System Agent Offset)
Voltage 4 0.72 Volts (VID #0)
Voltage 5 0.72 Volts (VID #1)
Voltage 6 0.72 Volts (VID #2)
Voltage 7 0.72 Volts (VID #3)
Power 00 6.62 W (Package)
Power 01 1.72 W (IA Cores)
Power 02 n.a. (GT)
Power 03 1.00 W (Uncore)
Power 04 3.90 W (DRAM)
Clock Speed 0 800.10 MHz (Core #0)
Clock Speed 1 800.10 MHz (Core #1)
Clock Speed 2 800.10 MHz (Core #2)
Clock Speed 3 800.10 MHz (Core #3)
Core 0 max ratio 39.0 (effective 8.0)
Core 1 max ratio 39.0 (effective 8.0)
Core 2 max ratio 39.0 (effective 8.0)
Core 3 max ratio 39.0 (effective 8.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x00100800 0x7FDAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x000027AB 0x00000000 0x9C000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3737342D 0x43204B30 0x40205550
0x80000004 0x352E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x00000048 0x00000000 0x00000000
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012300
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x25262727
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88490800
MSR 0x000001FC 0x00000000 0x0000005D
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x00000800
MSR 0x00000610 0x004283C0 0x001D8348
MSR 0x00000611 0x00000000 0x01835D4E
MSR 0x00000639 0x00000000 0x009CCEB3
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x00891767
MSR 0x00000614 0x00000000 0x000002A0
MSR 0x00000648 0x00000000 0x00000023
MSR 0x00000649 0x00000000 0x00000000
MSR 0x0000064A 0x00000000 0x00000000
MSR 0x0000064B 0x00000000 0x80000000
MSR 0x0000019C 0x00000000 0x884A0800
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x00001754 0x00000800
MSR 0x00000199 0x00000000 0x00000800
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x000306C3 0x01100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x01836CA8
MSR 0x00000639 0x00000000 0x009CD407
MSR 0x00000619 0x00000000 0x00891D5F
MSR 0x0000019C 0x00000000 0x88490800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x000306C3 0x02100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0x01837BAD
MSR 0x00000639 0x00000000 0x009CD932
MSR 0x00000619 0x00000000 0x00892378
MSR 0x0000019C 0x00000000 0x884D0800
MSR 0x00000198 0x0000172E 0x00000800
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x000306C3 0x03100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x000001B1 0x00000000 0x88480800
MSR 0x00000611 0x00000000 0x01838A98
MSR 0x00000639 0x00000000 0x009CDE4F
MSR 0x00000619 0x00000000 0x0089297B
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000306C3 0x04100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x01839958
MSR 0x00000639 0x00000000 0x009CE371
MSR 0x00000619 0x00000000 0x00892F14
MSR 0x00000198 0x00001737 0x00000800
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x000306C3 0x05100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x0183A83D
MSR 0x00000639 0x00000000 0x009CE89B
MSR 0x00000619 0x00000000 0x008934D3
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x000306C3 0x06100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x0183B72D
MSR 0x00000639 0x00000000 0x009CEDBD
MSR 0x00000619 0x00000000 0x00893ADB
MSR 0x00000198 0x0000174C 0x00000800
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
CPUID
0x00000001 0x000306C3 0x07100800 0x7FDAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x0183C66D
MSR 0x00000639 0x00000000 0x009CF31E
MSR 0x00000619 0x00000000 0x00894232
Storage
Drive 0
Name Samsung SSD 840 EVO 250GB
Revision EXT0DB6Q
Serial S1DBNSBF818892Z
Capacity 232.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 231.4 GBytes (15.2 percent available)
Volume f:\, 0.4 GBytes (96.9 percent available)
USB Devices
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x174C, product=0x2074
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x011A
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x005C
USB Device Generic SuperSpeed USB Hub, class=0x09, subclass=0x00, vendor=0x174C, product=0x3074
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8009
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8001
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Name NVIDIA GeForce GTX 1070
Board Manufacturer GIGABYTE Technology
Revision A1
Codename GP104
Core family 0x134 (GP104)
Technology 16 nm
Memory size 8 GB
Memory type GDDR5
Memory vendor Samsung
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x1B81 (0x3701)
Revision ID 0xA1
Performance Level 0
Core clock 139.0 MHz
Memory clock 405.0 MHz
Monitor 0
Model ROG PG278Q ()
ID ACI27B1
Serial #ASN0j+RoxMPd
Manufacturing Date Week 51, Year 2014
Size 27.2 inches
Max Resolution 2560 x 1440 @ 59 Hz
Horizontal Freq. Range 30-210 kHz
Vertical Freq. Range 30-150 Hz
Max Pixel Clock 540 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
  1. Have you done all the necessary updates? Win, GPU, etc updates.
  2. Did it start happening after you've installed some type of software?
  3. Check your PSU. See if you can get another PSU from Bestbuy or something for testing purposes.
