V VooSoo Commendable Jul 27, 2016 1 0 1,510 Jul 27, 2016 #1 I recently bought a used motherboard and saw that Power pin that connects to the power button for the case was broken. Is there anyway to boot my pc without using the power pin? Or is there a way to replace that one missing pin?? Its an ASUS b85m-g
Solution CountMike Jul 27, 2016 Somebody with soldering skills can solder new pin in. I changed many more important parts on MB using fine, low powered soldering iron.
CountMike Titan Oct 31, 2015 35,734 3,875 147,990 Jul 27, 2016 Solution #2 Somebody with soldering skills can solder new pin in. I changed many more important parts on MB using fine, low powered soldering iron. Upvote 0 Downvote Solution
J jay_rogers Reputable Nov 30, 2015 322 0 4,960 Jul 27, 2016 #3 BIOS will prevent the system from booting if CPU fan not plugged in or rpm too low Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,734 3,875 147,990 Jul 27, 2016 #4 jay_rogers : BIOS will prevent the system from booting if CPU fan not plugged in or rpm too low What does that have to do with start (power) switch ?? P.S. Fan monitoring can be turned off in BIOS and is usually off by default. Upvote 0 Downvote
T trenchcoatmafia Reputable Jan 15, 2015 19 0 4,520 Jul 27, 2016 #5 hi you just bought the mobo? just rma the mobo or 1 to 1 exchange. did you keep your receipt? Upvote 0 Downvote
