I am going to buy a msi b450 gaming pro carbon ac, with a ryzen 2600 and 16GB of RAM, if you need the model tell me and I will send it.
My power supply is the AEROCOOL KCAS 500w.
The mobo, (appart of the 24pin cable), needs a 8pin pcie+other 4pin-pcie.
My power supply only has two 6+2 pcie cables(and my gpu uses a 6pin cable). I have found on amazon this, and my question is that if you can tell me if that will work fine:
https://www.amazon.es/StarTech-com-8-Inch-Express-Extension-PCIEPOWEXT/dp/B007Y91B80/ref=mp_s_a_1_5?ie=UTF8&qid=1535362920&sr=8-5&pi=AC_SX236_SY340_FMwebp_QL65&keywords=power%2Bextension%2Bpcie%2Bcable&th=1&psc=1
Thank you.
PD:I'm spanish, so sorry if you don't understand something.
Thank you.
