My computer built in 2020 (upgraded occasionally since then) has been "haunted" for the last month or so with random shutdowns. Used to restart on its own but more recently it requires cycling the PSU on and off (MB and case lights are on, all fans are off). Been checking for problems with RAM, GPU, drivers, and Windows to no avail (also had to clear CMOS once or twice due to crashing in the middle of startup).
Last night my wife couldn't even get it to turn on. Powered on for me fine, I used it a few hours, had no problems. This morning, won't turn on for me. Clear CMOS, nothing. Disconnect power button and try shorting pins. Doesn't work at first, does eventually with repeated tries. And that problem is now persisting.
PSU is an Antec NeoECO Gold 700W. It has received unstable power from the wall a couple months ago (bad UPS battery), but it has never cut out completely. Motherboard LED was still on after all crashes.
Motherboard is Asus X570-P, BIOS version 4002. It has given me two minor issues in the past: Chipset fan doesn't always start (Fan Control can always kick it on from Windows), and during a POST it will sometimes give false alarms about not finding a display but then POST anyway.
So, I highly suspect the motherboard is bad, but could it be the PSU? How would (or can) I check the PSU before buying replacement parts?
