Motherboard Standoffs Help
Joewalk11
200
Ok so im thinking of getting a new case which is a mid tower ATX case - http://www.ebay.com.au/itm/Deepcool-Tesseract-SW-Gaming-Mid-Tower-Desktop-PC-Black-Computer-Case-No-PSU-/221868856707?fromMakeTrack=true.
The case i have atm is i think a micro atx with a micro atx board.
When i remove the motherboard and go to put it in the new case does the case have standoffs included or will my motherboard have standoffs already that i can use for the new case?
Stand-offs are usually something that are including with your case, rather than your board (though some do). Whether theyre pre-installed for you is on a case-by-case basis (get it? 😉 )
From looking at the images, the case in question does appear to have them installed, but it's not a guarantee.
If not, don't worry just remove the ones from your current case and use them in the new one :)
Thankyou!
