Question Motherboard temp is higher than cpu temp
Muhammad Jahid
Commendable
Jun 4, 2020
60
My motherboard temp is always at 56-60 Celsius at idle. but cpu temp is fine (never above 25-30 Celsius at idle)
I have tried to check the temp through HWinfo and speccy. Both are giving the same temp result.
Cpu: Core-i3 10105
Mobo: Bioster H510MX/E 2.0
Update your post to include full system hardware specs and OS information.
PSU: make, model, wattage, age, condition?
Disk drive(s): make, model, capacity, how full.
Fans: make, model, sizes, location, air flows?
Power down, unplug, open the case.
Clean out dust and debris. Inspect to ensure that nothing is blocking or otherwise interferring with airflows.
Check that all fans spin freely and are not damaged in some manner.
If possible take a photograph showing the inside of the case and post the photograph here via imgur (www.imgur.com).
Someone may spot something amiss.
