Question Motherboard VGA light on and no POST after 5 hour car journey ?
Figgle
48
Board: B450 Aorus M
Brought my working PC home in the car and after the ride, it won’t post. The VGA light is always on when I connect a vga câble from the mother board to the monitor. Similar results when running with my rtx 2060, although it worked for about 30 minutes before bluescreening and VGA light coming on again.
I've tried:
resetting cmos,
moving ram/ using only one stick of ram, and
disconnecting all cables from the motherboard and re connecting
If anyone had any ideas, please let me know. thank you!
full system spec? unless you have a APU. motherboard have no igpu output
check the rtx 2060 temp?
doesn’t seem like the gpu is overheating; it’s become much better now, turning on for hours at a time, but still blue screening occasionally and after every light bump. i’ll try to update with the full specs when i get it online again
if it blues screen after light bump. recheck all connection, device. something is loose
I don't exactly know what fixed it, but I reseated everything again and did a windows 10 disk repair from the advanced startup settings and it seems to be back in action. Thank you for the responses!
