Motherboard wont boot, beep or post with EVGA GTX 960 SC plugged into beefy PSU
John HD_1
Commendable
May 20, 2016
Motherboard will not boot or beep with the GTX 960 plugged into PSU. Everything works like a charm without GPU - if using internal GPU. Trying to upgrade kids PC for birthday. all help gratefully appreciated.:)
I have read endless posts here abut GPU and PSU but nothing works. Logic indicates its the GPU is bad, but... no real experience here. i need suggestions before i return the GPU.
If GTX 960 GPU is plugged into PSU, and I hit the lit MB power button it wont Beep or Post, but the PSU clicks once.
Problem still occurs when:
  • if GPU is not seated in PCIex16 slot, but plugged into PSU,
    if GPU and Motherboard are plugged into PSU and all drives are disconnected from PSU
    Using Red PCIe PSU cable with 8 pin on one end dual 6+2 pin on the other, tried both cables
    Tried combining two of the black 6 pin and 4 pin PSU connectors with the 2->1 adapter that came with GPU, same problem.
No Problem - good boot
  • if GPU is firmly placed in PCIEx16 slot but NOT plugged into PSU, everything boots. but the system does not see the new GPU
Other facts.
  • When PSU is on and the GPU is connected to it, the motherboard integrated power button is lit. when I press it, the PSU clicks and nothing happens, but light stays lit. if i press it again nothing happens, no click either. I have to toggle the PSU off and on again to get the little click again. I DONT UNDERSTAND IT, but it seems the PSU is tripping off but the Power button on MB stays lit.
    I don't have another PSU or MB or GPU handy for swapping
    Newest BIOS installed.
GPU: EVGA GeForce GTX 960 02G-P4-2962-KR 2GB SC GAMING, Superclocked ACX 2.0 2GB GDDR5 128bit PCI-E 3.0 16x Gra
MOBO: GIGABYTE GA-Z97X-GAMING 7
PSU: Thermaltake Toughpower 750W Power Supply Unit - ATX, 80+ GOLD, Black - PS-TPD-0750MPCGUS-1
HD: 2x Seagate Desktop Solid State Hybrid Drives - 1 TB, 8 GB NAND Flash - ST1000DX001
SSD: one solid state samsung 64gb
DVD: drive is there
RAM: Corsair CMX8GX3M2A1333C9 XMS 8GB DDR3 RAM -PC10666, 1333MHz, 2x 4GB
CPU: Intel Core i7-4790 Processor - BX80646I74790
Thanks
John
1) Try use the onboard intel iGPU to boot into the BIOS, check the setting graphics section, it should be in auto, or something like that, which means when you use a discrete GPU, the iGPU will be disable.
2) Try the gtx960 in other pciex16 slot.
If you still have the same problem, because you don't any other GPU to test, you just RMA the gtx960, or how test the gtx960 in your son or your friend PC.
The card has been RMA back to amazon. will see if that works with them. I guess the advantage of living in NYC is you can order something at 10 pm and its at my door by noon the next day. Bingo a second GPU to test with, and it works, so the first one is home bound to Amazon as defective. Thanks for responding. Onwards and Upwards! and one very happy 11 year old boy!
