Hi, I have an old asus p6x58d-e ws I had a while back and it booted on just fine. I had bent a few capacitors back in place with little force (weren't heavily bent inatially) before the boot so not sure if that's the problem. Then I shut down the build so I could get windows on my USB and tried to turn the system back on and it didn't power. I had turned it on and off quite a bit before this.
Specs:
Cpu: i7 920
Cpu Cooler: evga clc 280
Mobo: asus p6x58d-e ws
Hhd: wd black re2
Ram: g.skill sniper 8gb
Gpu: r9 fury
Power supply: rm1000x
Thank you in advance
Specs:
Cpu: i7 920
Hhd: wd black re2
Gpu: r9 fury
