Is the a mining motherboard that can use i5 3470 and ddr4 ram (6 gpu)(i know this isnt a mining forum but you guys helped me a lot in thr past) thank you
In general you would use a low power CPU, no need for a bunch of memory 8GB is fine and a riser card for the video cards, make your own open case to mount the cards.
What about a mining motherboard that can use an i 5 3470 or a i3 2120?
They didn't make mining motherboards back then. You just need a board with however many 1x PCI-E slots you require.
I use this board in a hodgepodge mining rig... supports 5 GPU's at once, with riser cards.
Asus P8Z77-V
