Mount a ViewSonic VX2370Smh on a VESA compliant stand?
th3m4dh4tt3r
19
Can any of you guys see a way to mount these monitors on a triple monitor stand? I like them because their bezels are flush with the rest of the display, and the bezels are also really thin. However, when you look at pictures of the back, it looks like some of the components are housed in the stand, which would make removing the stand and mounting it on a VESA mount very difficult, if not impossible. Furthermore, I don't even see any VESA compliant mounting holes. Have any of you ever used these monitors on a stand? How much modding would be required?
Link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116581&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
Thanks in advance!
P.S. I put this is Graphics cards because I didn't see a monitor subsection, if a MOD could move this post that would be great! Sorry for any confusion this causes, I'm really new to this site.
Hi Youngster,
VX2370Smh-LED is not designed for VESA mounting, so they cannot be mounted on a tripe monitor stand. However, our VA2342-LED and our professional display, VP2365-LED, are VESA compliant. Please see details below. Thanks.
VA2342-LED: 23" 5ms Widescreen LED Monitor 250 cd/m2 10,000,000:1 - http://www.newegg.com/Product/Product.aspx?Item=N82E16824116580&Tpk=VA2342-led
VP2365-LED: 23" 6ms Pivot, Swivel & Height Adjustable Widescreen LCD Monitor 250 cd/m2 DC 20,000,000:1 (1,000:1) - http://www.newegg.com/Product/Product.aspx?Item=N82E16824116509&Tpk=vp2365-led
ViewSonic
There is an adapter that works: http://www.amazon.com/Viewsonic-Monitors-VX2770SMH-LED-VX2370SMH-LED-VX2270SMH-LED/dp/B00Z8WZ7KS
