Mouse double clicks on pressing [Hardware problem]
kkiddu
219
My mouse seems to have got extra sensitive of late. If you hold down the button after clicking, it will more or less perform a double click.
Problems :-
-Almost impossible to drag and select text [Since another click deselects it]
-Sometimes leads to multiple windows closing if the 'x's are aligned, as in maximized
-Stuff like that
It's a hardware problem, I'm sure of that, since it doesn't happen sometime. The frequency is also reduced if I remove the mouse cover and use the actual button to click, although the button seems to have got loose [compared to the right click button, which is comparatively firm].
Should I check the wiring ? Sometime back, the wiring had got damaged [One of the four wires somehow broke] and I had joined it manually.
Or is it time to get a new one ? It's a 7 year old mouse, got it with my Compaq Presario SR1105IL. Laser, wired. Using XP.
Any way to prolong its life by a few months ? Reason being I'm getting a brand new PC in a few months anyway.
Got a new mouse. It's a HP wireless err..'wireless 3-button mouse'. Got it for $20.33. Might be a bit expensive, but this is India. Good tech here is expensive. Phones and tariffs are not. [Again, doesn't apply if you look at smartphones, which is 'good tech'].
One question : It comes with an on-off button. Do I need to turn it off everytime I get up ? Or only when it's not being used for prolonged periods ? (Runs off two AA batteries).
Few insights into the problem.
(1) DSP based mouse use chip to control freeze delay between individual click, if mouse is new this could be a manufacturing defect.
(2) As mouse ages, return spring of click button loses stiffness and bounces under clicks and thus produces several clicks for one.
Tough Fix:
Open mouse replaced click sensors on PCB by desoldering, switching places of sensors and resoldering.
*****Easy Fix*****
(1) Go to control Panel> Mouse >Double Click Speed and drag the slider to the middle between Slow and Fast.
(2) Download Utility MouseFix version 1.0 http://www.mediafire.com/?2cr4157s0rtnm44
(3) If rebinds keys and fixes double clicking, you can also use Left Shift as mouse click using this utility, Right Shift remains the same.
