Question Mouse losing BT connection
Badger51
39
I have a PC running WIndows 10
Edition Windows 10 Pro
Version 21H1
Installed on ‎2021-‎03-‎24
OS build 19043.1387
Experience Windows Feature Experience Pack 120.2212.3920.0
I recently replaced my trackball with a Logi ERGO M575. Installation proceeded smoothly and drivers are up to date.
My problem is that periodically, I appear to lose BT connectivity. The cursor is frozen and non responsive to any movements from the trackball. At times, a second BT mouse remains responsive. After a few minutes, or longer, the trackball BT connectivity resumes. At times, I see a message pop up "Starting Bluetooth device".
Any suggestions or ideas on how to remedy this problem. Of course, it only occurs when I am in the midst of something !
Thanks in advance.
Are you working with a desktop with a bundled BT adapter or a laptop? You might want to check and see what BIOS version you're on using CPU-Z. The BIOS version will be listed under Mainboard tab. Have you tried uninstalling and reinstalling your BT driver? When installing, I'd advise on manually installing the driver in an elevated command, i.e, Right click installer>Run as Administrator.
Ideally you should be on Windows 10 version 21H2, that's the latest version but I think your drivers are either corrupt or your BT adapter might need replacing.
I have a HP 18E7desktop, along with several USB BT adapters. One of the adapters is a LOGI Unifying bt dongle
This my Windows version:
Version 21H1
OS build 19043.1387
Bios:
BIOS
American Megatrends Inc. F60c (10/29/2020)
Sorry, I was interrupted.....the information above is my desktop pc which is giving me problems. I've tried using some troubleshooters from Windows and Logitech to identify the problem, without success.
I had two external bluetooth usb adapter and have removed one of them (the LOGI Universal one). I still have the problems where my LOGI trackball loses connections. Normally, in a few minutes, I see a popup, bluetooth device starting. Other times, I have to reboot to restore the bluetooth function.
I've tried deleting and uninstalling the logi device...
How would I find and delete the bluetooth driver, as suggested above. My device manager shows a number of bluetooth connections and devices.
Thanks
Addl information...
After reading some other posts , I checking my reliability history and found the following:
Source
Bluetooth Stack COM Server
Summary
Stopped working
Date
‎2021-‎12-‎08 7:40 PM
Report sent
Description
Faulting Application Path: C:\Program Files\WIDCOMM\Bluetooth Software\BtStackServer.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: BtStackServer.exe
Application Version: 12.0.0.9980
Application Timestamp: 54233bc3
Fault Module Name: BtStackServer.exe
Fault Module Version: 12.0.0.9980
Fault Module Timestamp: 54233bc3
Exception Code: c0000005
Exception Offset: 00000000000af0ba
OS Version: 10.0.19043.2.0.0.256.48
Locale ID: 4105
Additional Information 1: 3e34
Additional Information 2: 3e347bf46245ef69a4e5de3b72296149
Additional Information 3: 54d0
Additional Information 4: 54d09096ea216b6fdcef7fbfa7438735
Extra information about the problem
Bucket ID: 248d76ffc43b8fc3ff72370062207ded (86070788562)
