[SOLVED] Mouse Sensitivity Problems.
dinner
Commendable
May 28, 2021
30
Hello Lads. So i have a problem with my old PC And decided to buy a new one. I have setup the pc myself. All the Parts are new. ( Only left A PSU 350W.)
Mouse in game runs wild whenever i turn left or right or when im shooting When i turn to the right or left it keeps changing the sensitivity i guess cause it's not consistant.
Tried 3 Different Mousepads Including Zowie PSR, Steelseries Heavy , Steelseries QCK+. all the same
Enhanced Pointer Precision always OFF.
Don't know what to do any help would be appreaciated.
PC SPECS -
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i5 10400 @ 2.90GHz 36 °C
Comet Lake 14nm Technology
RAM
16.0GB Dual-Channel Unknown @ 1330MHz (16-18-18-38)
Motherboard
ASUSTeK COMPUTER INC. PRIME B460M-K (LGA1200) 27 °C
Graphics
ZOWIE XL LCD (1920x1080@144Hz)
4095MB NVIDIA GeForce GTX 1050 Ti (ASUStek Computer Inc) 30 °C
Storage
223GB OCZ-VERTEX460 (SATA (SSD))
Optical Drives
No optical disk drives detected
Audio
Realtek High Definition Audio
This is my PC Don't know why Speccy undetects the rams.
But ram are Ballistix 2.666Mhz 16GB.
Actually As stated above i checked all the setings and registry Wiped down 2 Times My Windows same..
Drivers are UP-TO-DATE.
RAM : MEMORY DIMM 16GB PC21300 DDR4/BL8G26C16U4R CRUCIAL
Have Tested With this mouses - Rival 110,Rival 300, Dream Machines DMS1 FPS
Also Have Tested With this Mousepads - Steelseries QCK+,Zowie PS-R,STEELSERIES HEAVY.
all the drivers for my motherboard is installed via app called Armoury Crate
Armoury Crate does not offer downloads for all drivers.
only those related to the Crate software and needed for proper communication between that software and your motherboard or other supported devices.
Audio, USB, Storage, Chipset, etc
all need to be manually downloaded and installed by the user from the specific board's manufacturer product support page(s).
But don't know how.
you would need to type in your motherboard model number into the search pane in the ASUS website.
from it's product info page select the Support tab.
if the issue persists over multiple mice;
than you either need to adjust sensitivity settings in Windows,
possibly reinstall any latest motherboard USB drivers directly from the manufacturer support page,
or if Windows just isn't properly reading the mice's dpi - perform a fresh drive wipe & OS install(not just a refresh).
if the mouse has any proper control software of it's own;
try using that to set the vertical & horizontal speed or it's average dpi.
Sensitivity in windows is set at - 6/11
Mouse Acceleration - Pointer Enhanced is turned OFF.
Tried to Uninstall USB CONTROLLER HUB - same.
Tried to Wipe out & Reinstall Windows 2 times.
these would not be the same thing.
your motherboard has particular drivers for it's onboard USB controller(s).
any USB "hub" connected is it's own separate USB host.
you should be installing the latest USB drivers from the motherboard manufacturer's support page.
even if you claim you're drivers are "UP-TO-DATE", this can still fix many issues that arise.
But don't know how.
