[SOLVED] Moved PC a tiny bit , heard buzzing noise and pc shut down .
Dec 18, 2019
Ok so I decided to move my new gaming pc I got yesterday ( prebuilt by cyberpower ) a few inches , I heard a buzzing noise and the pc shut down . I cant turn it back on and when I move the power cable with my fingers it buzzes when pc is plugged in . Please help
Make sure the power cable is fully plugged in. Best way to do that would be take it out and put it back in. Also check the connection to the powerstrip.
Reactions: JOK3RBO3
Ok so I disconnected the pc, turned off the psu and plugged it back in and it works so thanks a lot 😃 but I'm just wondering if i need a higher quality psu cable because it seems to move a bit and when the pc wasnt working made a short circuit noise when I moved it
Probably don't need a new cable. The noise you heard was what you would hear if you didn't have something plugged all the way into the wall. The PSU cable is exactly the same cable that you would find on electric typewriters from the 1970's.
