Question Moving Lines and Green Edge Monitor
if you are using the onscreen display of the monitor settings, is the green picture there as well? Then it´s the monitor
Could be the graphics card, do you have a spare or onboard graphics to test with or a different computer to test the monitor there?
How did you connect the monitor? check the cable or try a different one
My GPU is good. I have tried it in other PC. I think the problem is the monitor. Any monitor technicians? Is this repairable?
