MS-6178 - the highest speed of CPU?
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
MS-6178
Bus Clock: 100 megahertz
BIOS: Award Software International, Inc. 6.00 PG 08/07/00
With this Mobo I am using CPU, 750 megahertz Pentium III.
I wonder - is there any one here running Pentium III / 133 / 900MHz + ?
Jdr
There is another point regarding BIOS of MS-6178.
There are two BIOS being used by the MSI.
American Mega T. which is AMI .
And Award BIOS.
For some reason I can find only one AWARD BIOS Flash File,
but there is no AMI BIOS Flash available.
Any reason for that?
Jdr
"JDR" <jr@world.com> wrote in message news:2ju0o8F1599ufU1@uni-berlin.de...
> MS-6178
> Jdr
"JDR" <jr@world.com> wrote in message news:<2k00n1F15as0vU1@uni-berlin.de>...
> And Award BIOS.
> Jdr
> > MS-6178
> > Jdr
I recently upgraded to a PIII 900 100mhz, and it has been working fine
so far, got it for about $50.
I'm trying to figure out my memory upgrade possibilities at the
moment. I haven't read all of the threads here yet, but I've got 160
MB of SDRAM. The manual, as another poster named Johannes has pointed
out, is very confusing:
The mainboard supports a maximum memory size of 256MB(64-bit
technology)
or 512MB(128-bit technology for SDRAM: It provides two 168-pin
unbuffered DIMMs (Double In-Line Memory Module) sockets. It supports
8 MB to 128 Mbytes DIMM memory module.
I tried putting in a 256 in place of my 32, but the machine only saw
128 mb of it. Crucial's sight had a specific type of RAM that would
work for all 256, but it was like $90.
If you can help me out, I'd appreciate it.
Thanks,
BD420
"bd420" <bd420@hotmail.com> wrote in message
news:97f3e1c7.0407191836.4771d5fe@posting.google.com...
> > > MS-6178
> > > Jdr
> technology)
> Thanks,
> BD420
Hi,
I don't know whether it helps but:
There might be a couple of reasons, why your System shows only half of the
memory.
1. The Memory chip is wrongly marked (it's not 256 MB but 128 MB only)
2. The memory chip is not 100MHz but 133MHz
3. the propriety chip is somehow incompatible.
The best would be to check memory chip in other computer.
Take also a diagnostic aplication Belarc which in my
case reads:
http://www.belarc.com/free_download.html
512 Megabytes Installed Memory
Slot 'A0' has 256 MB
Slot 'A1' has 256 MB
SiSoftware Sandra http://www.sisoftware.net/?location=update
System
Manufacturer : Elonex PLC
Mainboard
MP Support : No
Model : MS-6178
Number of Memory Slots : 2
Bank0/1 - A0 : DIMM 256MB/64
Bank2/3 - A1 : DIMM 256MB/64
Chipset 1
Model : Intel Corporation 82810 810 Chipset Memory Controller Hub
Bus(es) : ISA PCI USB i2c/SMBus
Front Side Bus Speed : 1x 100MHz (100MHz data rate)
Maximum FSB Speed / Max Memory Speed : 1x 100MHz / 1x 100MHz
Width : 64-bit
Logical/Chipset 1 Memory Banks
Bank 0 : 128MB SDRAM 3-3-3-0CL
Bank 1 : 128MB SDRAM 3-3-3-0CL
Bank 2 : 128MB SDRAM 3-3-3-0CL
Bank 3 : 128MB SDRAM 3-3-3-0CL
Shared Memory : 1MB
Width : 64-bit
Refresh Rate : 15.60µs
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : Kingston 4MX64PC100CL2 168P 02076900 512MB 16x(32Mx8)
SDRAM PC100-222-622 (CL3 up to 100MHz) (CL2 up to 100MHz)
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (33MHz)
PCI Bus 1 : PCI (33MHz)
Multiplier : 1/3x
>> And Award BIOS.
>> Jdr
>>> MS-6178
>>> Jdr
> technology)
> Thanks,
> BD420
Your 256Mb module must only be a single sided 256Mb module.
These will NOT work in these boards.
You will need to get double sided 256Mb modules to be able to expand the
RAM to the maximum.
These are more expensive than the single sided stuff, but thats the
price you pay for owning and upgrading these older boards.
HTH
MaX
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.727 / Virus Database: 482 - Release Date: 26/07/2004
