Msgsrv32 not responding
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Amd 1.4 ghz
512mb DDRAM
40 gig hd 7200rpm
Leadtek Geforce 2 pro 64mb
Sidwinder Precision Pro 2 Joystick
Win 98
While playing games with a joystick everythings works for about 20 minutes then the game freezes, I then press CTRL,ALT & DELETE and the task box comes up and in the box there is a program called Msgsrv32 and it is not responding. I then close this program down and the game returns and works but the Joystick does not work and this problem has occurred with two different joysticks. I have tried the microsoft site and the solutions do not work.
I would appreciate a solution as I am new to computers and I am getting frustrated.
Drew Reese
blaireese@optushome.com.au
you say it happens after about 20 mins, have you tried running it with the case open? sounds to me like it may well be a heat problem.
Next time you wave - use all your fingers
Are you using a screen saver? Maybe this will help, see article <A HREF="http://support.microsoft.com/support/kb/articles/Q169/9/87.ASP" target="_new">Q169987</A> Hopefully it is something easy to correct.
However, this article is commonly for Win95, it could be another application running in the background. If so, try repetitive Ctrl-Alt-Del, ending task on everything except EXPLORE & SYSTEM TRAY. If the problem goes away then you'll have to test each background program one at a time (trial & error) style until you find the problem child.
JC-------<*){{{>{~~~~~
Fisher of men
