I recently have realized that one of the two fans of my MSI TwinFrozr III Radeon 7950 Boost Edition graphics card is not spinning. This is the fan closest to the hard drive bays, the rear fan is fine. Temps are pretty ok, running at a max of 75 degrees(c) underload on the gpu core, while running on about 70 degrees(c) on both VRMs.
I am using the AMD Catalyst Beta driver 14.4 (updated not too long ago)
What should I do? Re-install the driver or downgrade to 13.12? Or remove the graphics card and clean it then put it back in?
My system specs:
Motherboard - ASRock 970 Pro3 R2,0 AM3+
CPU - FX-8320 @ 3.7Ghz
OS - Windows 8.1 Pro 64-bit
RAM - 8GB (4GBx2) 1600Mhz
PSU - Corsair CX600 v2 (80+ Bronze)
My system specs:
