msi afterbunner problem
Jirokarja17
22
Hello, im using msi afterbunner for OSD along side of RTSS. all my other game work fine. but when i play heros of the strom i dont get the OSD at all. ive tryed manually putting the exe in RTSS but that didnt work. could someone explain why this is going on. is it because of alpha.
No brother dosn't look like.I'VE GOTTA SOLUTION FOR YA,cuz' i once had the same stupid problem with OSD. All u gotta do is -》1. Go to your browser and google - HWINFO(u will easily get the latest version) 2. Download it 3. Open HWINFO and select the option 《SENSORS-ONLY》and launch the application. 4. GO OVER TO THE OSD TAB(also run RIVA TUNER in the backround) it should be showing RTSS in brackets. 5. Select the info you want to display on-screen and apply the options 6.run both together in system tray 'n' enjoy! It will be showing OSD forcefully in any app run with your gpu. ;D
argh i really didnt want to download HWINFO for just one game when all the rest are working with afterbunner. really just wanted to know if anyone esle was having this issue with hero of the storm
Some games simply don't work with MSI Afterburners monitor. In the few cases it doesn't work, I downloaded Fraps for monitoring FPS.
