Question msi afterburner not recognizing gpu after fan replacement
LukaNyan
20
EDIT: I uninstalled the drivers using DDU instead of amd cleanup utilities and now MSI afterburn works just fine.
After replacing the fans of my R9 290 tri-x with fans from the XFX SWFT rx 6700 xt, msi afterburner stopped giving any information whatsoever. HWmonitor only shows GPU utilization and memory.
I can control the fans just fin in the amd radeon software and the temperature seems correct, but I want to use MSI afterburner as well. Any solution? Can't seem to find many info about it online smh
View: https://imgur.com/a/e7dCc63
"This:
"I can control the fans just fin in the amd radeon software and the temperature seems correct, but I want to use MSI afterburner as well".
Why both?
My thought is that using both (or trying to use both) may be contradictory or causing some conflict.
The fan change(s) could also be a factor with respect to msi afterburner no longer giving information.
And you could end up going in even bigger circles if problems develop.
I recommend staying with the AMD Radeon software. All the more so if the temperatures, fan speeds, etc. are controllable and seem correct.
Keep it simple. Anything else may mask a problem until it is too late....
Just my thoughts on the matter.
