Libraers :
Seanie280672 :
Libraers :
Same like the title, i just build a new pc but i cant enter the bios. It has 3 times beep sound from the motherboard.what's that mean ? Any help ?
Specification :
Msi b350 arcrtic tomahawk
Ryzen 5 1600
Ram team dark pro 4GB ddr4 3200
Vga galax gtx 1060
Ssd 120gb
Hdd 2tb
3 beeps is a ram problem, it doesnt like your ram, try just one stick on its own, or you'll have to try some different ram.
I trying to place one stick on itss but still got 3 beep sounds.
Oh yeah, the beep sounds its like 1 long beep and 2 beep shorts.
Oh, 1 long and 2 shorty is different, thats graphics card error, first of all, you need to make sure the card is fully seated properly in the slot, when screwing the card tight into the slots on the case, this can pull it slightly out of the slot without even realising it, so double check that its completely in there, also, some card have a default output port that you're supposed to use first, it maybe that you have to use that one, and finally, make sure, if it requires it, you have the power cable to the graphics card plugged in correctly.
