toughrough Jan 11, 2020 8 1 15 Mar 21, 2020 #1 https://www.msi.com/Motherboard/B450-GAMING-PRO-CARBON-MAX-WIFI Does this board come with argb header? Or regular rgb headers?
Solution ChumP Mar 21, 2020 Yes that mobo has both, regular RGB and ARGB headers. Motherboard schematic from the manual: The RGB headers are the JRGB1 down there (near the JAUD1), and the JRGB2 near the CPU power connector. The ARGB header is the one called JRAINBOW1 near the JUSB3 header. RGB and ARGB reference from the manual :
ChumP Splendid Sep 16, 2014 3,408 286 28,390 Mar 21, 2020 Solution #2 Yes that mobo has both, regular RGB and ARGB headers. Motherboard schematic from the manual: The RGB headers are the JRGB1 down there (near the JAUD1), and the JRGB2 near the CPU power connector. The ARGB header is the one called JRAINBOW1 near the JUSB3 header. RGB and ARGB reference from the manual : Reactions: toughrough Upvote 1 Downvote Solution
toughrough Jan 11, 2020 8 1 15 Mar 22, 2020 #3 Thanks man. Appreciate it👍 Reactions: ChumP Upvote 0 Downvote
