Question MSI B450 tomahawk max Jack problems.
Industryy
64
5
4,535
Hello guys I've recently built my computer, the problem is that the jack device doesn't work, I've tried to put my headphone and no sound go out of it.
When I put my other headphone on only USB it work but when I go with the other on jack the Realtek panel recognize it but no sound on youtube.
I've tried to put again back the wires of the mobo and checking if everything it's fine, all it's ok...
The HD audio port are plugged right too... So i don't know how to fix it....
Thanks guy
Hello,
Do you have a gpu also.
Open sound setting and check what is the default sound option Realtek or your gpu internal audio.
and have connect in middle green jack backside of motherboard panel.
If its front panel then you can manually change it in Realtek hd audio manager in setting you can select disable front panel jack detection.
Of course, here you go
About the settings audio :
And for the Jack It use 3.5mm, the headphone that I use to test It's :
THE G-LAB Korp Vanadium.
