Question MSI B450M PRO-VDH MAX
LXIXMcNeill
The case that I am planning to use with the MSI PRO-VDH MAX motherboard comes with 3 RGB fans and 2 normal fans will i need a splitter to use them with this motherboard.
The motherboard comes with:
  • 1 x 4-pin CPU fan connector
  • 2 x 4-pin system fan connectors
  • 1 x RGB LED strip connector
So it will also depend on how the RGB is powered. If it is through a MB pin strip connector, then only 1 will connect to the motherboard.
I have just seen that the case comes with a controller with a 4 pin molex cable. Is that good enough?
