MSI GTX 1070 gaming x 8GB cooling system?
Bernty
4
So i have a question, is it possible to install water cooling on my card? (MSI GTX 1070 gaming x 8GB) like are there any brackets that i need to get and what cooler should i get if its possible to do it?
I tried to look it up if anyone has done but i can't find any info or anything about this, and i'm kinda new to this stuff as well.
Are you talking about an AIO or a waterblock? I'm not aware of any AIO solutions for that card, you could probably fit a kraken G10 on with some modifications but that will take some fabrication skill. Why do you want to water cool it? That cooler is well known for being cool and quiet already. Also, this exists so they have no incentive to make an AIO kit for the gaming model.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814127961&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Video+Card+-+Nvidia-_-N82E16814127961&gclid=Cj0KEQjwnsPGBRDo4c6RqK-Oqu8BEiQAwNviCa4v_MbTQX2bBLyi6jo9ochuUGolcutOQIam6N4EZakaAnw88P8HAQ&gclsrc=aw.ds
Yeah i'm talking about AIO and i know its known to be cool and quiet..and my card is quiet, but not cooled enough. i dont have good air flow in my cabinet so the heat from the card heats up the whole cabinet and i didn't think of that when i bought the PC.
Yeah maybe i should buy a new card, and no i can't cut a hole on the back of my cabinet 😛 i'll just open it on the side for now to get more air i guess but thx for the help though i appreciate that! 😀
