Hello, all! This is my first post here, and sadly, it isn't a happy story.
My MSI GTX 980,
this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127834
-is only running at PCI-E X2 3.0 (and some times flickers down to 1.1).
I thought this may just be an error with GPUZ's reporting, so I did some benchmarks. Sure enough, when a benchmark is not bandwidth heavy, like FurMark, it performs better than a stock GTX 980. However, it chokes on anything that requires cpu->gpu bandwidth. D3D Bandwidth tells me my VM to SM and SM to VM speeds are only 1340 MB/s and 1282 MB/s respectively.
I thought it was a problem with the card, but other cards do the same thing in that slot (even my old 8800 Ultra runs at PCI-E x2 1.1). Therefor, I thought it was the motherboard (it came with a dead RAM channel as well, GIGABYTE G1 Gaming GA-Z170MX-Gaming 5) so I RMAed the motherboard and got a new one, an ASUS Z170M-PLUS.
The same problem persists after all Windows 7 updates, all driver updates, most recent bios installation, most recent GPU driver installation, making sure no power save was effecting PCI-E state, checking BIOS for all settings that could effect it (tried PCI-E slots set to legacy only and UEFI, no noted change), and am pretty much at my wit's end here.
Is there a chance it could be an issue with the processor somehow? It's all I can think of.
My system information is:
Windows 7 64 bit
16 gigs of DDR4, dual channel, at 3000 mhz
Core i5-6600 @ 3.3 ghz
480 gb SSD
EVGA Supernova 750W
MSI GTX 980
Any and all help is appreciated!
My MSI GTX 980,
Windows 7 64 bit
480 gb SSD
EVGA Supernova 750W
MSI GTX 980
