MSI H110M PRO-VD DRAM and CPU led on
idonthaveanid
Commendable
Dec 21, 2016
I decided to build my own computer and bought all the parts on Black Friday of this year. When I finished building the computer I noticed that the EZ debug led was on for the DRAM and occasionally switched to the CPU led for a moment. I decided that it was the RAM at first but that still didn't work out. I plugged in the RAM in another computer and the RAM worked. I was told by my friend's that it was probably the motherboard that was the problem. I replaced the original motherboard (MSI B150M) and decided to use a MSI H110M instead. THe light is on for this motherbard as well and the computer is not booting to the BIOS, does anyone have any ideas? My specs include the Cooler Master Elite 431, 600w EVGA power supply, PNY Anarchy 16GB DDR4, Intel i5-6500, MSI H110M (Current motherboard)
Just because it worked in one PC doesnt mean its compatible in another one. What model RAM is it?
And B150 is better than H110 so not a great choice.
What do you mean what model is the RAM? If you're asking for the manufacturer it's PNY.
All RAM have model/part numbers, as there are dozens of different versions. On the RAM itself there shoulkd be a model number.
