Question MSI MPG A850G vs FSP Hydro G Pro 850W
Mar 12, 2024
Hi there,
I am torn between those two PSUs and they cost the same where I live, which one would you pick out of the two ?
Thanks in advance.
where I live
Where would you be located? As for the question about your PSU, are these the only two you have as options? What will the PSU be powering?
Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
Chassis:
where I live
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
Chassis:
CPU: Ryzen 7500f
CPU cooler: Thermalright Frost Commander 140 or Peerless Assassin 120
Motherboard: MSI B650 Gaming Plus or Tomahawk WIFI
Ram: Lexar Ares 6000Mhz CL 30
SSD/HDD: Kioxia Exceria Plus G3 2TB
GPU: Sapphire 7900 GRE Nitro +
Chassis: Corsair 4000D
There is also the Seasonic Focus GX-850 but I heard the internal parts aren't as good as the ones MSI use. Is 850W overkill or should I keep it for future upgrades?
