MSI Mystic Light not showing Corsair ML120 RGB PRO
Nov 7, 2018
4
Hello.
I just installed the msi mystic light from my new msi x470 gaming plus.
And i noticed i can't control the light from the software.
I have both command hub and lightning node pro.
Do i really need to use iCue only to control the led from fans?
Thanks,
If your MSI motherboard has a JCORSAIR header, you can connect that to the RGB Fan Hub and control the fans from there. But with the Lighting Node Pro, that's only controllable via iCue.
