I need some help. I just purchased an MSI P35 Neo Motherboard Ver. 1.0
CPU 2.66Ghz E6570
RAM that I have tried - OCZ Platinum 2GB Sticks 800mhz/ OCZ Gold 1GB Sticks 800mhz / 2GB Fatility Sticks 1066mhz G-Skill 1GB Sticks 800mhz
Video Cards I have used - GTX260 - 8800GT - ati hd5670
500 Watt Cooler Master With 2x18amp 12+
and
500Watt Thermal Take 2x 16amp 12+ Rails
No matter what combination of the hardware above I use it goes into a boot loop eaither right after post, right at windows start-up or if im in bios.
Some combinations word better as far as the RAM goes. 1 stick seems to be a little more stable but still leads to bootloop within a minute and before windows starts. the 1066Mhz memory also seems more stable.
Also sometimes depending on how much RAM is in wont start at all just powers on with no signal. If I mess with timings it SOMETIMMEs makes it seem more stable but still...boot loop by the time Windows is starting.
I flashed bios to latest one. But before and after flash it has some issue. I think I flashed to 1.A?
Heat isnt the issue.
It aslmost seems as if its something between the CPU and RAM as far as speed/timings/ratio or soemthing! If i remember right I actually got it into windows on a Q6600 CPU but it still had reboot issues I must have had it set just right in bios?
I'm thinking I should flash to a different bios not sure what one. I just really need this thing to work!
Please Help!
Brian.
CPU 2.66Ghz E6570
and
Please Help!
Brian.
