Question MSI PRO Z690-A shows red CPU light when booting ?
idris_al_mamri
22
so i got together this pc build :
MSI PRO Z690-A ProSeries Motherboard (DDR5)
i5-13600kf
32 gb ram ddr5@ 5600mhz
palit rtx 3090 Gaming Pro
cx850m corsair psu
When i turn it on, the CPU red light at the bottom turns on (vga, boot and others stay off), the pc stays on for a less than a minute and then turns off, and then goes into a booting loop.
I tried these solutions and none of them helped :
  • Update the bios (in fact i tried flashing all the bios versions separately to see if any of them will work, none of them did, and the i install them correctly)
  • Remove and clean the CMOS and put it back.
  • Reinstall the cpu (some websites said this error may be caused by incorrect installation of the cpu)
so whats wrong here ? did i do something wrong or am i missing something ? thanks in advance.
