Hi so I'm currently having an issue with my graphic card and overclocking it.
Graphic Card - MSI 9750 Twin Frozr Boost OC
Default Clocked at - 960MHz and 1250MHz
Driver Version - Crimson ReLive 17.4.4
Main Monitor BenQ XL2720Z 27 inch 144Hz Gaming Monitor
Second Monitor (that im having the issue with) - ASUS VN247H 23.6in Widescreen LED Monitor
So im trying to overclock my Graphic card so I can get better performance from the old girl but every time I try and move slider up by one to 961 for the core clock or memory clock my second monitor starts to glitch out and produces these black and white bars that make the screen shake and move everything down for only a few seconds then then goes away but as soon as I move my mouse around starts doing it again.
I tried using different cables to see if the same problem is happening and it still does.
Not sure what else I can do so if anyone knows a fix or something it would be helpful.
Thanks
Thanks
