A Alncst Sep 26, 2019 10 0 10 Sep 26, 2019 #1 Does this graphics card actually need both 8 pin and 6 pin cables connect Ed to work?
Solution logainofhades Sep 26, 2019 Yes, and don't use adapters. If your PSU is not up to the task, get a proper, quality PSU, with necessary wattage and cables.
rgd1101 Don't Moderator Nov 7, 2011 73,313 3,855 176,290 Sep 26, 2019 #2 unless the manual said other wise. yes. Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 37,557 3,222 143,290 Sep 26, 2019 Solution #3 Yes, and don't use adapters. If your PSU is not up to the task, get a proper, quality PSU, with necessary wattage and cables. Upvote 0 Downvote Solution
A Alncst Sep 26, 2019 10 0 10 Sep 26, 2019 #4 Ok that also answered my next question thanks. Upvote 0 Downvote
