MSI RX 470 to vga monitor
I've already tried DVI-D adapter but I get no signal, I bought an HDMI to VGA cable, still doesn't work.
Are you certain that VGA cable with a DVI-D adapter works?
unfortunately no, i have had luck with these in the past but not sure if modern GPU's support VGA anymore
I've also tried to connect the monitor to a R9 390 but didn't work out.
Monitor works fine when I connect it to old graphics card with vga to vga cable, so, all the cables and "hardware" works perfectly, the problem here is the connectivity, or monitor just doesn't accept signal from new graphic cards, it's like the signal from r9 390 and RX 470 is too "strong" for the monitor to handle it, or..?
In theory DVI-D to VGA adapter should work right? I think this is my only option, if this doesn't work, I will just use the old graphics card until I but a new monitor.
No it didn't dude, thank you in advance, you both just answered pretty much the same answer so I just replied with a more generally post.
What do you mean "active"? active DVI-D to VGA adapter? (forget option 2, it's so expensive 😛 )
