After rebooting my computer earlier today, my computer refuses to boot. Here’s my hardware setup, which has remained untouched for six months, and has worked fine up until today:
Original setup (from 2017)
MSI Tomahawk B350
Fractal Design Integra M 550W PSU
AMD Ryzen 5 1600 Processor
Corsair Vengeance LPX DDR4 3200MHz 16GB (2x8 GB)
Added later (early 2023)
ASUS Radeon RX 6650 XT DUAL OC - 8GB GDDR6 SDRAM
Corsair Vengeance LPX DDR4 3200MHz 32GB (2x16 GB)
Here’s what I know
MSI Tomahawk B350
Here’s what I know
- The monitor works on a different computer
- The HDMI cable works
- CPU and case fans are all spinning
- The graphic card fans stop spinning after about 5 seconds (but I read online that this might be as it should, considering that they GPU is not hot at all)
- The CPU EZ debug LED lights up for about 5 seconds after pressing the power button, then goes dark; no other EZ debug LEDs lights up after that
- The MB backlight is on (red light from behind the board somewhere)
- I’m not sure if I can access BIOS, but probably not (screen black)
- I’m reasonably sure the OS doesn’t start
- Left only one RAM stick in the A2 slot
- Unplugged computer for 15 minutes
- Unplugged the computer for 8 hours
- Checked CPU fan power cable
- Swapped the graphics card for an old one I know works
- Used theHDMI port on the motherboard
- I've also tried removing the GFX card and unplugging everything except CPU+fan and one stick of RAM in the A2 slot, but the behaviour is identical: the CPU LED lights up for roughly 5 seconds, then goes dark, and no other LEDs light up whatsoever.
