Question MSI x570 XMP problems with with ryzen 5000 series
Switch87
62
Hello,
Finished my build today, I'm using an MSI MEG X570 Unify and a 5800X with an RTX 3080.
My pc doesn't post if I enable XMP. I get 07 and must clear cmos. I'm using the latest bios that was released yesterday I believe.
My ram is G.Skill Trident Z Neo DDR4 3600 PC4-28800 32GB 2x16GB CL16 .
Since then I managed to run the ram at 3200mhz 1.35v 18, 18, 22, 22, 42 .
Anyone else having problems with XMP and 5000 series with maybe other Msi boards or this one?
Kind of an annoying situation, I'm unsure if I got a bad ram kit or if it's due to the bios.
EDIT: The beta bios listen here as of 10/11/20 seems to have fixed it for most people!
Reactions: dened
I am glad it solved your issue. I have tried it too, but sadly no luck. Have to wait for new bios, I guess...
Actually, it seems like if I change BIOS settings slightly I get 0d code again, so probably I was just lucky enough to find settings that work for me. But even that might be not the case, 3DMark Time Spy is very unstable for me, I get reboots and crashes all the time even without overclocking. But Karhu RAM Test doesn't show any memory errors, so it's probably is not related to memory.
There is known issues for the x570 Unify on the MSI forums.
MSI have rushed their AGESA 1.1.0.0 bios and there are repeated claims of the following issues.
  • CPU temp not being read by peripheral software [such as AIO cooler software]
  • Mystic Light RGB sync not identifying ARGB peripherals [such as RAM and system fans]
  • XMP profile not working past 3200Mhz
  • Overclocking stability is horrible for BOTH ram and CPU
MSI haven't official put out a notice of anykind and are just being silent about it for now. Let's hope they get their <Mod Edit> together.
Reactions: dened
View: https://www.reddit.com/r/MSI_Gaming/comments/jpvxz4/the_bios_incompatibility_for_zen_3_is_being_under/?sort=new
Reactions: dened
Yes, I am also one of them with a new 5900X and MSI X570 Ace motherboard latest bios version and can max hit 3200Mhz with my G.skill 3600C16 TridentZ neo (F4-3600C16D-32GTZNC). And Everything was working fine with my 3900X which is sold btw.
It is also my assumption that it must be a bios f''kup. Have someone tried with other memory modules?
My assumption is also that is has not been tested since the RGB is not recognized either hence it is not supported by the motherboard. You can check it against the QVL...... wait there is none for the 5000 series 🙁
That its my next question for support.
I contacted MSI they told me they are aware of ram issue.
In the meanwhile to be able to post with XMP do the following:
Enable XMP and after manually change Fckl to 1600 and you will be able to post.
@dened - Thanks man - after the bios update to version: E7C35AMS.1D1, Now I was able to apply the 3600Mhz xmp profile :) You are the man.
One thing - The RAM is still not recognized by the Mystic light SW, I will try reinstalling it :)
Update, I just swapped out my MSI X570 Unify with an ASUS X570 ROG STRIX E Gaming and DOCP (XMP) booted right up no issue at 3600 FLCK 1800 on my GSKILL Trident Neo 3600 CL16 kit
Updated BIOS to E7C35AMS.A81 from https://forum-en.msi.com/index.php?threads/msi-x570-b550-beta-bios-update.348919/.
So far it's working well at DDR4-3600CL16.
I can confirm that using the bios file E7C35AMS.1D1 for the X570 Ace works. I also see that there are no more WHEA warnings/errors and the benchmarks are stable using XMP 2. Thanks @dened 👍
Also - related to this - the MSI motherboard support page has uploaded updated chipset drivers, so it is now the same as those that come from AMD (more or less).
Be sure also to also check and enable Wake up from USB in the BIOS settings to enable the mouse and keyboard to wake up from sleep. I found it odd that it is disabled by default. Go to Settings -> Advanced -> Wake Up Event Setup -> check that Resume By USB Device is enabled.
Cheers everyone!
Hi all !
I'm running the same problem with my config : MSI B550 Tomahawk, 5800X, Tuff 3070 and 32Go memory (2 packs of 2X8Go) ballistix 3600Mhz CAS 16.
I've tried many things but it's impossible to get 3600Mhz or 3400 and even 3200Mhz is crashing.
Yesterday i tried with only 2X8Go and it worked perfectly ... but with 4X8Go it crash...
i think it can be a problem of this 2 packs that didn't work well together, i don't know, i'm waiting an aswer from MSI atm.
maybe i'll return my memory and choose a pack of 4X8Go from G-skill Ryzen edition.
i'm french, sorry if my english's not perfect
Cheers everyone!
Hey there! I have same mobo but still can’t get stable memory with my GSkill Royal 4000mhz cl15. Only able to get 3200mhz with that bios.
are you running XMP? Or custom settings?
I'm in a similar boat as the rest of you. Running the 5900X with 64GB Crucial 3600MHz DDR4 on my MSI X570 Prestige Creation. The latest beta BIOS I can get is 7C36v1C2 released on the 13th. No further updates yet. At 3200MHz everything boots and runs fine. Even the slightest bump to 1633x2 for 3266MHz and it does the error code 07 and won't boot, regardless of voltage or other settings. Even with relaxed timings it won't post.
For reference, this same motherboard with this same RAM worked amazingly with my 3900X. I was able to run the speed above 3600MHz (I think I got all the way to 3800MHz) in addition to tighter timings than specified. It was glorious! Even though this CPU is significantly faster, it would really be nice to run my RAM and motherboard at settings I know it is capable of.
I encourage everyone to keep complaining to MSI until they fix this. I didn't try the "C" beta BIOS with the 3900X, but I did try the "B" beta BIOS that came out right before it with improved 5000 series support, and all my settings, including XMP (3600MHz) on the RAM worked just fine.
Hi, I realise that, my issue is more in the doubt of if it's the kit that is bad or if it's a bios problem. I'm pretty sure it's the bios, so I'll just wait it out.
Thanks
Hi, i faced exactly the same problem, but after updating on bios version 7C84v14 , i have no issues
