[SOLVED] MSI Z370 A PRO MOTHERBOARD there are no 12v rgb header HELP !!!!!
Jan 21, 2019
MSI Z370 A pro motherboard have no 12V rgb
i bought msi phanteks 400 mm RGB strip when i was putting it.
it saw that i did not have the RGB header on the mother board i checked the picture on msi page and checked that it does not have the RGB header man
IDK what to do now??
any help would be aprecciated
You return the LED strip, get a new motherboard, or get a 12v RGB controller.
An Arduino can be used as one with some work. There are also some controllers that are RF remote and you plug a special cable or module (supplied) into the led strip and the the PSU (for 12v)
