[SOLVED] Msi z490 ace cpu cable
Jul 21, 2020
14
So I bought the msi z490 ace for my new build and it has two 8 pin power connectors for the cpu. My problem is I can't find cables the will plug into them. It's not the 4+4 design or the 6+2 it's they are the exact same plug as what is on the psu. Does anyone know where I can get cables or adapters I've checked newegg and a few others with no luck. THANKS!
Success I got one of my cables to work the other will not. Now my question is can I turn it on with only one of the cpu power plugs being used? I'm using the i7 10700k if that matters.
Second one is optional in case of large overclocking or using many devices in PCIe that take power from PCIe slots. Bot of them shoud have same socket configuration.
They do plug in as this is a standardised connector, but can be a bit confusing and if not aligned properly will not go in. You should be able to tell the right way by looking at the 8 pin CPU port on the motherboard as each hole is slightly different from square shaped to slightly oval type shapes. This must be aligned with the CPU power cables that came with your PSU and the 4 + 4 design must lock together the right way.
It's a 750 watt thermaltake rgb but I've even looked into a new corsair and evga and both of those have two 8 pin cpu outputs but the cables split to 4+4 which doesnt plug into it.
Also one way is putting the first 4 pin port in and then the second into the single 8 pin port on the CPU.....That's how I did it on mine with the Gigabyte Z490 Aorus Ultra. My PSU the EVGA 850 G3 Supernova also came with 2 x 4 + 4 CPU power cables. Sometimes these cables can be confused with the PCIe GPU power cables, so double make sure they are the CPU power cables...
That's what I thought but the square to rounded dont match up. The end that plugs into the psu will plug right into either of the plugs on the MB but the 4+4 square and rounded edge pins are not in the same spot. Its literally the only thing keeping me from firing up the beast too. I will post some pics of what I've got going on when I get home tonight.
Yep it would be good to see some pics as this is confusing....
Reactions: vMax
