[SOLVED] MSI z490 MPG gaming edge wifi getting cpu not detected / fail on 11700k
xsplattermusic
52
Hello, today I was making a switch from AMD to Intel. Upon turning on my PC, everything seems to be working, the GPU fans are spinning, my liquid cooler is working just fine. I'm getting a white light on my mobo below the CPU tag. I'm not getting a boot / no signal on my screen.
My specs:
MSI z490 MPG Gaming edge wifi
i7 11700K
MSI 3080
850 PSU
I have a 1TB HDD Drive but when I made the switch I also inserted a M.2 drive (This wasn't in my previous build.)
New DDR4 ram 3200 mhz
I'll provide any feedback, thank you so much
My guess is that the Mobo is old (got it from best buy) and needs a bios update?
I checked up the list of the boards with flashback BIOS in the Z490 and the I/O shield to see if it had a BIOS button and a USB port made for that and it doesn't seems like it has that.
The board does not have BIOS Flashback so you guys will need a CPU supported first by your board to BIOS flash it.
Version
7C76v27
Release Date
2021-02-04
Description
  • Update ME 14.1
  • Support Re-size BAR function to enhance GPU performance including the Nvidia GeForce RTX 3000 series and others.
  • BIOS updated to be compatible with 11th Gen Intel Processors
  • Improved compatibility of PCIe-based devices.
Any chance you found out if it was possible to update the bios without the cpu? I’m in the same boat, 11700k w/ that board. Don’t have a previous gen cpu to do the update with
