[SOLVED] MSI Z590 Pro M.2 Limitation???
Michale32086
Commendable
May 24, 2020
6
MSI Z590 MB...
It has 3 onboard slots for 3 M.2 SSD chip drives..
I have 2 running and a 3rd SSD SATA drive that has all the COD/BATTLENET Game files..
Installed a 3rd M.2 SSD I was going to use for my email program... When I did that, the SATA SSD disappeared...
I pulled the 3rd M.2 and the SATA SSD reappeared..
Is there an M.2 limitation I am not aware of??
Thanx in advance...
Problem solved..
I guess adding the 3rd M.2 drive takes away the 2 SATA connections from the motherboard..
I put the SATA SSD on the block of 4 SATA connectors and it worked fine..
Whew!!! Dodged a bullet there..
Problem solved..
