I submitted the following issue to MSI support:
I have been using this MSI motherboard with no problems until last month when my WD Gold™ Enterprise Class SATA HDD - 18TB drive began clicking quite loudly and then no longer showed up on Disk Manager. It also then blocked the OS from booting up as long as it was attached to the MB. Previously, I also began to have errors with the main OS drive (Hitachi HDS724040ALE640 [Hard drive] (4000.79 GB) and a WD Gold Enterprise Class SATA HDD-12 TB drive, all attached to this motherboard. When I ran HD Tune Pro, it would show "Number of interface communication errors: 61 that might be caused by damaged cable" on each of these drives. I changed all the SATA cables but the errors kept showing up. The loud clicking of the 18TB drive was quite worrisome as it indicated to me imminent failure, but I was at a distant site and needed to still use the PC and data on the drive. Then the drive failed altogether. I didn't do anything further with it, not wanting to compound the problem. I wanted to wait and see if connecting the drive through a USB docking station would permit me to see the drive again.
When I got back home, I connected the drive to another computer but this time through a StareTek USB 3.0 Drive docking station. Holding my breath, I spun up the drive and fortunately it showed up and I could see my data. I then bought a WD Gold 20TB drive to backup the data on the 18TB drive. I don't want to attach the 18TB drive directly to either PC until I have the data safely backed up. I am now suspecting that their could be some problem with the SATA ports on the MSI motherboard as the loud clicking was only heard when it was attached to the MSI PC. Once I backup the data I will connect the 18TB drive directly to the PC with a ASUS Z97-A-USB31 Rev 1.xx motherboard. If the drive reads OK but then falters on the MSI PC, it would imply, to me, that something is faulty on the MSI SATA ports.
Is there anyway to trouble shoot this problem and determine where the malfunction is coming from?[/I]
Their response was that the drive was incompatible with this motherboard and I need to choose another drive from their very restrictive list.
I read of no potential drive incompatibilities when I read over the motherboard manual before buying this board.
As ths drive cost over $500 as did the 20TB drive I just bought to back it up, I would like to know if anyone can recommend any help for this problem.
The fact that the 18TB drive worked fine for 1 year and only recently started to show extreme signs of failer (loud clicking leading to loss of registration on the OS, but works on another PC, seemes to indicate a problem with the MSI SATA controllers or something along that line.
Any help would be appreciated.
Thanks,
Doug
PS: the support site for this motherboard shows three updates:
Intel Chipset Driver
Intel Rapid Storage Technology Driver
Bios
Any chance these might help?
Thanks,
Doug
Bios
