MSI Z97 PC Mate need help to disable intergrated graphics
hedzerr
29
I need help disabling the intergrated graphics on my mobo.
I can only find a switch between IGD and PEG on the setting intergrated graphics configuration.
It's set standard on PEG, but when i start gaming my pc reboots and will start using the intel hd 4600 graphics. I tried another card in the mobo and it did not have the problem, i tried the card i have problems with in another computer and it did not have problems.
I can change in PCI subsystem settings PEG X to PCI E gen 1, 2 or 3 and i can adjust the latency timer.
