Multi Bluetooth Transmitter
Oct 24, 2018
5
I need to buy a Multi Bluetooth transmitter which is compatible with my Samsung Smart TV Series 7 can anyone help please
Paperdoc
Polypheme
Ambassador
Not sure how you want to do this. Are the two speakers to be used completely separate (e.g, in different locations)? Or, are they a PAIR of stereo speakers in one location. I would expect a stereo pair to be "one" speaker for BT purposes.
But I'll assume you really do need two independent speakers. I found this on the Canadian Amazon site, but I'm sure you can find it (and other similar?) on like sites.
https://www.amazon.ca/dp/B07BQYYDNJ?aaxitk=ybSMK4WoKPjLADI4gZICTw&pd_rd_i=B07BQYYDNJ&pf_rd_m=A3DWYIK6Y9EEQB&pf_rd_p=4cca1e3c-4d42-4151-86ab-9344d5a24403&pf_rd_s=desktop-sx-top-slot&pf_rd_t=301&pf_rd_i=bluetooth+transmitter+for+tv&hsa_cr_id=3472120530801&sb-ci-n=asinImage&sb-ci-v=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F61jmGv7TWRL.jpg&sb-ci-a=B07BQYYDNJ
If you expand the answers to the first Customer Question question on that page, it details how to get two separate devices to pair with this device. Above that, in the section of Frequently Asked Questions from the seller, Q3 deals briefly with possible problems when using two DIFFERENT models of speaker. The device has a "pass-though" mode so that you can pass audio signals through this device and on to a nearby wired speaker set, and still transmit to the Bluetooth devices simultaneously.
Oct 24, 2018
5
5
I have been looking at the avantree devices they look OK but what I need to know is how they connect to the TV by wire or Bluetooth as its a smart Samsung series 7 and the leads in the back are different
Paperdoc
Polypheme
Ambassador
The Avantree device comes with a few cables for connections. It includes an optical cable you can connect to the device's Optical input port from a TV. The other end of that can go to the Optical Digital Audio output of the TV's rear panel. Check if your TV has that port. Check its manual for any details that may help. Once that connection is made, connection to your Bluetooth devices should be easy. If you want also to connect in pass-through mode to a nearby speaker set, you can use either the Avantree device's analog AUX output jack, or its optical digital output if that's what your speaker system can use.
Well, the Samsung TV can register several devices and save them. You can then freely switch between both speakers but you won't be able to use both speakers at once.
If you connect the USB dongle to a PC though, most standard 10$ Bluetooth Dongles will allow 4 to 6 different Bluetooth devices connected at the same time (i.e: mouse, keyboard, speakers, etc...)
However, even on a PC, you'll have to chose which speaker to use if you connect two different ones.
Paperdoc
Polypheme
Ambassador
julienruc has an interesting idea for doing this from a PC, and maybe that can work from a Samsung TV, too. I'd guess it depends on whether the software tools for uie on a PC can be used for similar pirposes on the TV. On the other hand, that Avantree device appears not to require any "smarts" in the TV. It simply accepts the TV's audio output signal and uses its own minimal "smarts" to send that on to up to 2 different Bluetooth devices plus the "pass-though" option to a wired speaker set.
