Multi-monitor Setup: Better CPU or better GPU?
zlnxid
Commendable
Jul 31, 2016
So I'm a bit new with computers, and am going to build a setup with a few monitors for productivity reasons. I might also do some gaming, though I'll only be using one monitor (or 2 at max) for that purpose. They are all of full HD resolution, btw.
My question is, with that kinda setup, would I be better off with a better CPU or a better GPU? Which would make my overall experience better? Should I get an i7 with a low-end GPU (I.e. gtx 950) or an i5 with a midrange GPU (I.e. gtx 1060)?
Depends on what i7 you were planning on getting, if you were planning on 4 core i7 then the i5 gtx 1060 combo will be better but if you were planning on a 6+core i7 then it's worth it to save on gpu.
149$ for 4GB RX 470 and 119$ for 4GB RX460 i don't see how that is "hell of a lot more expensive" for better performance.
