Multiple Bluetooth Sound Outputs into One Speaker?
I want to combine the inputs so that I can use them simultaneously
I know, that's not going to happen on that speaker.
Briefly skimming that device, no that will not combine 3 separate bluetooth signals into one signal to pair to the speaker.
Even if it did, it would be quite hilarious to spend $80 on a mixer to output sound to a $25 speaker.
Yeah, I guess so. I'll just use the built-in speaker for the Google Home and a cheap wired mixer to combine the aux out on my PC and Mac into a good Wired speaker. (First world Problems) Thanks for the help.
You could only connect one Bluetooth device to that mixer.
You will have to use the other inputs (stereo, RCA, MIC) to get more than one audio stream
By the way that device doesn't look like it can power a MIC, so make sure to have one that does not need power.
