Okay, so this is my first build and I've used this forum extensively to troubleshoot these issues. Finished the build Friday night and shortly after got the memory management BSOD, followed today by a few others in rapid succession.
Specs:
OS: Windows 10 Pro 64-Bit
Mobo: Asus TUF B360M Plus Gaming
Processor: Intel i5 8400
Ram: 1x8GB DDR4 Corsair Vengeance 2400 MHz
PSU: EVGA 450BT
SSD: Crucial MX500
HDD: WD 2TB
GPU: EVGA GTX 1060SC
What I've done so far:
- Updated the bios
- Downloaded all mobo drivers from Asus
- Downloaded all drivers for chipset and ethernet from intel
- Downloaded newest driver for GPU from EVGA
- Ran memtest overnight (8 passes) - no errors
- Examined minidumps using WhoCrashed and BlueScreenView, and WinDbg
It's worth mentioning that this is an entirely new build aside from the GPU and HD's - these were previously used in a Dell workstation before migrating to this build. I'm not sure if that would have any bearing on these issues, but I figured I'd mention it. I also uninstalled Norton anti-virus after getting the memory management BSOD.
Looking at the dump files, they all point to ntoskrnl.exe.
Here is my crash dump analysis:
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Mon 1/14/2019 5:37:51 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011419-6609-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1B1B40)
Bugcheck code: 0xEF (0xFFFFB78B07D9C540, 0x0, 0x0, 0x0)
Error: CRITICAL_PROCESS_DIED
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a critical system process died.
There is a possibility this problem was caused by a virus or other malware.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Mon 1/14/2019 5:35:50 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011419-7046-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6783A0)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8047B0873A0, 0xFFFFBA83F113F048, 0xFFFFBA83F113E890)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Mon 1/14/2019 7:37:41 AM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011419-7515-01.dmp
Bugcheck code: 0xA0 (0x10E, 0xA, 0x511, 0x2BFC)
Error: INTERNAL_POWER_ERROR
Bug check description: This bug check indicates that the power policy manager experienced a fatal error.
This is likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue).
On Sun 1/13/2019 1:08:30 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011319-6875-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFEA80062CF1C0, 0x0, 0x1)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred. A page table page has been corrupted.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
Any information would be greatly appreciated. I'm kind of stabbing in the dark for the moment.
EDIT: Ran sfc /scannow and it returned this message:
"Windows Resource Protection found corrupt files and successfully repaired them.
For online repairs, details are included in the CBS log file located at
windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline
repairs, details are included in the log file provided by the /OFFLOGFILE flag."
Specs:
PSU: EVGA 450BT
SSD: Crucial MX500
HDD: WD 2TB
- Updated the bios
C:\WINDOWS
C:\WINDOWS\Minidump
