Multiple BSOD problems
fredwntr1
6
Ive been having multiple blue screen errors 4 different codes to be exact
Dump File : 012915-19984-01.dmp
Crash Time : 1/29/2015 2:23:34 PM
Bug Check String : NTFS_FILE_SYSTEM
Bug Check Code : 0x00000024
Parameter 1 : 000000b5`00190637
Parameter 2 : ffffd000`3b76c178
Parameter 3 : ffffd000`3b76b980
Parameter 4 : fffff801`79f31ba4
Caused By Driver : Ntfs.sys
Caused By Address : Ntfs.sys+a9a5
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+14f1a0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\012915-19984-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 9600
Dump File Size : 373,664
Dump File Time : 1/29/2015 2:24:49 PM
Dump File : 012115-15140-01.dmp
Crash Time : 1/21/2015 8:02:54 PM
Bug Check String : KMODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x0000001e
Parameter 1 : ffffffff`c0000005
Parameter 2 : fffff802`e2f027e2
Parameter 3 : 00000000`00000000
Parameter 4 : ffffffff`ffffffff
Caused By Driver : hal.dll
Caused By Address : hal.dll+5ff2
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\012115-15140-01.dmp
Major Version : 15
Dump File Size : 325,416
Dump File Time : 1/21/2015 8:03:53 PM
Dump File : 012115-20953-01.dmp
Crash Time : 1/21/2015 5:01:14 PM
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c0000005
Parameter 2 : fffff802`b8b1eba4
Parameter 3 : ffffd000`23f867d0
Parameter 4 : 00000000`00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+14f1a0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\012115-20953-01.dmp
Major Version : 15
Dump File Size : 323,840
Dump File Time : 1/21/2015 5:02:10 PM
Dump File : 011515-35578-01.dmp
Crash Time : 1/15/2015 10:52:51 PM
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 2 : fffff802`128bf9a2
Parameter 3 : ffffd000`201ef748
Parameter 4 : ffffd000`201eef50
Caused By Address : ntoskrnl.exe+389a2
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+389a2
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\011515-35578-01.dmp
Major Version : 15
Dump File Size : 348,312
Dump File Time : 1/15/2015 10:54:04 PM
i was led to believe this was a ram issue so i bought new ram even reinstalled windows 8.1 and nothings changed. Here is my specs
cpu: 8350
motherboard: msi 990fxa-gd80v2
ram: corsair vengeance 1600mhz 16GB
hdd: 500GB toshiba
psu: evga 600w
gpu: gtx 760 evga acx
all my drivers are up to date except most of the motherboard drivers are windows default drivers if that matters because my motherboard doesnt really support windows 8.1. i had the same issues using windows 7 as well though
id also like to point out that i have a slight bend on one cpu pin but it installed in the socket just fine and this problem has been only recently
it also seems the blue screens happen a lot more often when i am running a dual monitor setup
i tried the repair from the dvd and whocrashed said that one of the memory dumps was from avast antivirus so i removed it but the blue screens are still there. id like to mention also that it usually crashes while im playing games especially when im trying to use obs to stream. is it possible that my 2GB graphics card isint enough? if not it may be the motherboard?
this means avast could need to be update or had block a virus could you post the whocrashed result also did you do memtest on each ram module and try with one of them at the time in the system ,for the gpu playing at high settings and streaming in the same time could be asking to much from it .
